Parsing Complex XML with XFMap
  • Nov 7, 2017 6:38 PM UTC
  • 94 views
runneals
Forum|alt.badge.img+32
<?xml version="1.0" encoding="utf-8"?>
<SDDOT>
  <item>...</item>
  <item>
    <id>497751</id>
    <status>active</status>
    <categories>
      <category>
        <name>conditions</name>
      </category>
    </categories>
    <descriptions>
      <description>
        <phrase>dry</phrase>
      </description>
    </descriptions>
    <locations>
      <location>
        <route>US-212</route>
        <direction>Both Directions</direction>
        <start>
          <lat>45.0056</lat>
          <lon>-102.8765</lon>
          <milepost>71.713</milepost>
          <landmark>
            <place>Mud Butte</place>
          </landmark>
        </start>
        <end>
          <lat>45.0231</lat>
          <lon>-102.0451</lon>
          <milepost>112.715</milepost>
          <landmark>
            <place>Junction South Dakota 73 South-Faith</place>
          </landmark>
        </end>
      </location>
      <location>
        <route>SD-73</route>
        <start>
          <lat>45.0231</lat>
          <milepost>166.445</milepost>
          <landmark>
            <place>Junction US 212 East-Faith</place>
          </landmark>
        </start>
        <end>
          <lat>45.0231</lat>
          <lon>-102.1095</lon>
          <milepost>169.608</milepost>
          <landmark>
            <place>Junction US 212 West</place>
          </landmark>
        </end>
      </location>
    </locations>
    <time>
      <start>
        <unixtime>1510070857</unixtime>
        <local_time>2017-11-07T09:07:37 MST</local_time>
      </start>
      <end>
        <unixtime>1510243620</unixtime>
        <local_time>2017-11-09T09:07:00 MST</local_time>
      </end>
      <announce>
      </announce>
      <update>
      </update>
    </time>
  </item>
  <item>...</item>
</SDDOT>
I need to get 2 features out of this, 1 for each <location> tag. How would I go about doing that? Currently I'm parsing out on each item. It threw an error when I attempted to read in the following:
<feature-map multi-feature-construction="true">
    <mapping match="item/locations/location">
       <feature-type> <literal expr="Feature"/> </feature-type>
    </mapping>
 </feature-map>
xfmap-sd-iris.xml
Best answer by daveatsafe
Hi @runneals,
The attached Xfmap should get you the locations with the attributes you want:
locations-xfmap.xml
Alternatively, you can use the Feature Paths Configuration Type in the XML reader read the locations from that XML data:
Enable Flattening to get the attributes:
The Feature paths is not as powerful as an Xfmap, but it is a lot simpler to use.
daveatsafe
Forum|alt.badge.img+24
  • Nov 7, 2017 9:10 PM UTC
Hi @runneals,
locations-xfmap.xml
runneals
  • Nov 7, 2017 10:06 PM UTC
Hi @runneals,
locations-xfmap.xml
Is there any way to get the attributes outside of the locations path?
daveatsafe
  • Nov 7, 2017 11:29 PM UTC
The easiest way to do that is to use the Feature Paths with Elements to Match set to 'SDDOT/item'. This will produce a single feature for each item with the locations as a list. Use a ListExploder to explode the locations.location{} list.
If you really need to use an Xfmap, I am attaching a modified copy of xfmap-sd-iris.xml that will also create a list for the locations. In the workspace, add a ListExploder to explode the list location{}.
location-list-xfmap.xml
runneals
  • Nov 8, 2017 6:35 PM UTC
Hi @runneals,
locations-xfmap.xml
Thanks! I need to go outside my comfort zone and parse xml besides using xfmap
