Parse ESRI Json file output, add new static variable, then rewrite back to Json file with new variable
  • Oct 14, 2021 10:08 PM UTC
  • 71 views
Hello,
I have a few ESRI generated json response files from ArcGIS Server feature service that can contain 1 to 200 records per response and these do not have geometry.
What I want to accomplish is to add one new parameter "projectnumber" and assign it with a static variable and rewrite the output back to JSON or ESRI JSON file again.
Thanks in advance !
Original:
  "attributes": {
  "sapfloctplnr": "MASG-GASD-SA01-SERL-0055647",
  "lifecyclestatus": 1,
  "GLOBALID": "{E839E029-529F-4D6B-9C4E-85BD875BC582}",
  "ASSETGROUP": 1
  "attributes": {
  "sapfloctplnr": "MASG-GASD-SA01-SERL-0055649",
  "GLOBALID": "{A9BF1A40-C1E4-4BC7-A538-7011FA9C55EA}",
  "ASSETGROUP": 1
  "attributes": {
  "sapfloctplnr": "MASG-GASD-SA01-SERL-0055659",
  "GLOBALID": "{2C931767-555B-44CB-B8B0-EFD345FCD324}",
  "ASSETGROUP": 1
Desired output:
  "attributes": {
  "ASSETGROUP": 1,
"projectnumber": :123abc"
  "attributes": {
  "ASSETGROUP": 1,
  "attributes": {
  "ASSETGROUP": 1,
daveatsafe
Forum|alt.badge.img+24
  • Oct 14, 2021 11:14 PM UTC
Hi @litung8​,
You can use a JSONFragmenter to split up the source JSON into features. Set Flatten Query Result into attributes to Yes to extract the JSON info as attributes. Then use the JSONTemplater to build the new JSON, including the Project Number. I am attaching a workspace to illustrate.
Forum|alt.badge.img+54
  • Oct 15, 2021 7:56 AM UTC
You should also be able to use a JSONUpdater to do this
  • Oct 15, 2021 3:03 PM UTC
Hi @litung8​,
Thank you @daveatsafe​  This works great ! I spent many hours trying to get this output - you saved the day :)
