Parameters changes in HTTP Caller for Cityworks- windows authentication ?
  • Jul 21, 2023 3:07 PM UTC
  • 103 views
jaygrg111_
Forum|alt.badge.img+9
I am trying to change the authentication from local to windows authentication in Cityworks. What changes do I need in HTTP Caller parameters? Is the chosing NTLM (username, password) under "Authentication" section enough or do I need to add something under "Header" or other parameters?
Best answer by sanaeatsafe
Our Cityworks Web Connection uses the token authentication requests listed in their API Documentation. I've also successfully used the CityworksConnector to produce the token, then passed that token directly into the HTTPCaller parameters to authenticate the request. Unfortunately, I haven't come across any other types of workflows besides those. A good first step might be to check with the Cityworks support team to confirm what your authentication options are for their API.
sanaeatsafe
  • Jul 26, 2023 10:07 PM UTC
jaygrg111_
  • Jul 28, 2023 7:29 PM UTC
@sanaeatsafe​  Thank you! It works now.
