Parallel roads into centre line
  • May 21, 2019
  • 42 views
I am trying to simplify a road network, turning many parallel roads into a single line. Is there a way to do this?
Forum|alt.badge.img+48
You can buffer the lines (to an extent that the buffers of parallel lines overlap eachother, then dissolve the buffers (possibly grouping by a street name or something like that) and create centerlines out of them.
