Pairwise combinations help
  • Aug 23, 2016 4:30 AM UTC
  • 96 views
Hi guys, I've been struggling for a couple of days with the following conundrum, hoping someone can offer some guidance.
I have an input containing one attribute (sa2_code) with 2000 region values in numeric format (example value: 101011002)
I have a second input containing one attribute (year) with roughly 20 different year values.
I would like to merge the two such that each region code is duplicated 20 times with each different year value. eg:
sa2_codeyear10101100219911010110021992......101011002201010101100319911010110031992......1010110032010
I've tried feature merger and joiner in loops but can't seem to get them working for this task. I find the
Any suggestions?
Thanks in advance.
Matt
  • Aug 23, 2016 5:17 AM UTC
Hi @mattj84, I would use the FeatureMerger and ListExploder.
  • Send the features having region code to the Requestor port, send the features having year value to the Supplier port.
  • Set an identical value (e.g. "1") to Join On parameter for both Requestor and Supplier. The FeatureMerger with this setting performs unconditional merging.
  • Check "Generate List" and specify a list name (e.g. "_list") to the "List Name" parameter.
  • Then, connect a ListExploder to the Merged port to explode the output features on the "_list{}".
Alternatively, the InlineQuerier that performs CROSS JOIN may also be effective.
  • Aug 23, 2016 5:31 AM UTC
If the range of years is fixed (e.g. 20 years between 1991 and 2010), the Cloner could be a quick way.
