overshoot cleaning using MRF2D Transformers
  • Apr 4, 2018 5:24 PM UTC
  • 39 views
lianaolianov
Forum|alt.badge.img+5
Hello,
I'd like to know how to remove overshoots using the MRF Cleaner
I have tried the MRFIntersector followed by MRFShortGeometryRemover but this didn't work properly? I didn't also understand what does the MRFIntersector cleaning tolerance mean.
thank you.
fmelizard
Forum|alt.badge.img+22
  • Apr 26, 2018 5:36 AM UTC
mrf-cleaning-v1.fmw Hi @lianaolianov The tolerance works like a snapping tolerance. If the features are within the tolerance then one end will snap and there will be no dangle. If the distance is greater than the tolerance then the remaining dangle can be removed by a MRF2DDangleRemover.
