overlay sat image and vector ,
  • Jun 11, 2018 7:48 PM UTC
  • 9 replies
  • 65 views
boubcher
Forum|alt.badge.img+11
Hello There
I am looking to get export all feature to the image but with the sat image background
I used image fetcher transformer, the problem is I am getting only one feature on the image and the translation shows 5
for the info I am using the Google Static image url
Forum|alt.badge.img+63
It seems the images you pull out of Google are not georeferenced so the Data Inspector shows them all on top of eachother. If you have it group by layer_id for example you can see it's different tiles.
That would make it harder to overlay the parcel boundaries. You may want to try the Landsat or Sentinel on AWS readers instead (they do return a georeferenced image)
boubcher
  • Jun 12, 2018 11:27 AM UTC
@redgeograhics
how could we group them by layer id , I dont see any option for that
boubcher
  • Jun 12, 2018 11:30 AM UTC
@redgeograhics
The parameters of the Inspector transformer. Mind you, that only groups them for the inspector.
boubcher
  • Jun 12, 2018 11:46 AM UTC
Still didnt work I am getting the same results five images each one with layer ID
Yes, that's what I said. The images are not georeferenced so FME can't display them in the proper geometric relation to eachother. Try the Landsat or Sentinel one instead (they're also free to use, which may not be the case with Google)
boubcher
  • Jun 12, 2018 12:45 PM UTC
@redgeographics
Thanks for your help any reference on how we could use those sat images
@redgeographics
There's a tutorial here https://knowledge.safe.com/articles/43678/tutorial-reading-and-working-with-satellite-imager.html
Sentinel is probably the best one to work with, I haven't tried Landsat myself to be honest.
boubcher
  • Jun 12, 2018 1:35 PM UTC
@redgeographics
Thanks for the information
I did tray the sentinel, but the resolution is an issue, compared to Google Map
Again thanks for you help
