Overlapping Input parameter in old version of Dissolver
  • Mar 23, 2020 4:27 PM UTC
  • 79 views
Forum|alt.badge.img+54
An old version of the Dissolver (Version 3) has a parameter called overlapping input which can be set to Overlap or No Overlap
Can anyone recall what the difference is?
Best answer by david_r
Wow, that's an old version. Even FME 2014 has the Dissolver at version 11.
Found this nugget, hope it helps:
Source: https://desktop.arcgis.com/en/arcmap/latest/extensions/data-interoperability/pdf/FMETransformers.pdf
  • Mar 23, 2020 4:37 PM UTC
  • Mar 23, 2020 4:39 PM UTC
Thanks, i think that confirms for me that if Overlap was set then the current dissolver should do the same thing (but better!) and I'll hope I don't find one using the No Overlap function
  • Mar 23, 2020 4:51 PM UTC
Agree, I understand it the same way as you. If, for some reason, you find one using the No Overlap option, you could perhaps to do some magic with e.g. the SpatialRelator first.
