overlaping polygons statistics
  • February 18, 2014
  • 5 replies
  • 71 views
jaro
Hello there,
anyone got an idea how to get statistics from the values of the points underlying the polygons? My polygons are unfortunately overlaping, the spatial filter doesn't work. The Spatial relator is not available in this project. I just need a sum of the values.
Thanks in advance,
J.
fmelizard
Forum|alt.badge.img+22
  • February 18, 2014
Hi Jaro,
Use a PointOnAreaOverlayer with a list name specified, after that a ListSummer can sum up the attribute values.
jaro
  • February 18, 2014
Hi Itay,
unfortunately, the client's FME version is "basic" which neither has PointOnAreaOverlayer available. I need to develop a workaround to this, which seems to be quite difficult.
J.
jaro
  • February 18, 2014
Yupi! The Orientor, Geometrycoercer, LeftRightSpatialCalculator, Listexploder and Statisticscalculator does it!
  • February 19, 2014
Hi Jaro,
Good to hear you achieved the goal.
Another approach.
1) Branch the flow of polygons into two streams.
2) On one stream, append 0-based sequential index to each polygon with a Counter (Count Output Attribute: _index, Count Start: 0).
3) On another stream, count the number of polygons (use Aggregator. Count Attribute: _count, Keep Input Attributes: No), merge the count attribute to every point unconditionally (use FeatureMerger. Join On: a constant e.g. 1), and create copies of every merged feature i.e. point (use Cloner. Number of Copies:  _count, Copy Number Attribute: _index).
4) Filter points by polygons with a SpatialFilter (Group By: _index).
5) Calculate sum for each group with a StatisticsCalculator or Aggregator.
Takashi
jaro
  • February 19, 2014
OK, yours is faster.
