Output data not reading as specified EPSG code
  • Oct 14, 2021 8:46 AM UTC
  • 78 views
mattenvsys
Forum|alt.badge.img+4
Hi all,
I am generating a workspace for a client. A requirement is that output data should be in EPSG:29902.
The writers have been defined to use 29902 as the output coordinate system. However, when I open the datasets in QGIS or Arc, the data is reporting as coordinate system EPSG:29903.
Is there a way to correct this behaviour? Attached is a simple workbench with a creator transformer and a writer set to use 29902. But the output generated is 29903.
Many thanks
oscard
Forum|alt.badge.img+23
  • Oct 14, 2021 9:44 AM UTC
Which EPSG code shows the FME Data Inspector? Maybe FME is doing the job OK.
Also, check the definition of the EPSG:29903: https://epsg.io/29903
There it says the PESG:29902 was replaced by the EPSG:29903 in 1975.
mattenvsys
  • Oct 14, 2021 10:38 AM UTC
Hi oscard. Hmm, you are right. FME inspector is showing EPSG:29902 and so is the coordinate system extractor transformer
oscard
  • Oct 14, 2021 10:41 AM UTC
If the EPSG:29902 is obsolete, that could be the reason QGis shows the other one. According to the definition, both coordinate systems are similar.
oscard
  • Oct 14, 2021 10:43 AM UTC
You could try this: get two outputs. One with EPSG:29902 and the other one with 29903. Open both of them with FME Data Inspector and compare the coordinates of the same vertex in both outputs.
