Original Color from Civil 3D DWG file changed to black/white
  • February 15, 2024
  • 7 replies
  • 128 views
myadegaryiutac
Forum|alt.badge.img+9
I am converting a Civil 3D DWG file to GDB. However, once I read the DWG file, the colors appear to be changed to black and white. I attempted to use DWGStyler, but the colors are still not reverting to their original state. I've checked the Reader Parameters to ensure that "Resolve Entity Color" is selected. Could someone please assist me?
1 more thing that I found is that, once I use autocad_color or fme_color in DWGStyler the values disappear.
Thanks in advance
Best answer by daveatsafe
FME’s colors do not apply to features with Surface or Solid geometry. For these, you must set appearances on the feature with an AppearanceSetter.
The Civil 3D reader seems to add the appropriate appearances to the Structure 3D features, but not the Pipe or Pressure Pipe 3D features. You can add these appearances using the following process:
daveatsafe
Forum|alt.badge.img+19
  • February 15, 2024
myadegaryiutac
  • February 16, 2024
thanks @daveatsafe  for your response.
I set the AttributeExposer, AppearanceStyler but once I wanna use AppearanceSetter and set the color to fme_color, it looks like the only option I have for that is User Parameter
myadegaryiutac
  • February 16, 2024
@daveatsafe here is the screenshot
myadegaryiutac
  • February 16, 2024
I was trying to assign a simple color and run just to make sure if it works or not, that I received the following error
Unmatched reference encountered in 'C:/Users/Temp/
wb-cache-DWG to GDB-zLKVew/Main_AppearanceSetter -1 61 fo 0 OUTPUT  0  0ed5a1cb74c6d24072d51b65722dd680f03446ba.ffs'.  It could be that a FFS file is missing the associated FRS file.
An error has occurred. Check the logfile above for details
Failed to read features
daveatsafe
  • February 16, 2024
You don’t have to set the color in the AppearanceSetter. The appearance created by the AppearanceStyler will supply that for you. Please leave the color settings in the AppearanceSetter untouched.
myadegaryiutac
  • February 16, 2024
Thanks @daveatsafe for quick response
I am receiving these error
Unmatched reference encountered in 'C:/Users/***~1/AppData/Local/Temp/wb-cache-DWG to GDB-sADUOh/Main_AppearanceSetter -1 115 fo 0 OUTPUT  0  e1786f0d3f6eb1a9e96ba8d65789bb1158aed30c.ffs'.  It could be that a FFS file is missing the associated FRS file.
daveatsafe
  • February 16, 2024
Please try turning off Feature Caching, from the Workbench top menu Run option, then try running the workspace again.
