One attribute to multiple using regEx
  • Oct 16, 2017 5:31 PM UTC
  • 7 replies
  • 196 views
Hello,
I am having difficulty finding something similar to this in the Knowledge Center so I thought I would ask.
I have an attribute whose value looks like this (it is a full line from a badly formatted text file).
Ticket No: 4653 Nearest Intersection: Chinton Street Seq No: 34
I need them split to an attribute list and subsequent value list
Eg:
Attribute_1 = Ticket No
Value_1 = 4653
Attribute_2: Nearest Intersection
Value_2: Chinton Street
Attribute_3: Seq No
Value_3: 34
It doesn't have to be a "list" as long as I can separate those part of the texts. I am guessing there should be a RegEx way of doing this.
The attribute names "Ticket No", "Nearest Intersection" and "Seq No" will always remain the same with their values changing. I am trying to build a script to always separate them.
Any suggestions? Thank you!
Addition:
For the first one, if there was a way to extract between 'Ticket No:' and 'Nearest' that would be fine. I can work with the formatting of the value afterwards.
I have 19 lines with the same formatting problems. With 2-3 attributes per line. I am trying to avoid too many transformers per line. If I could possibly use an attribute creator where I create the new attribute and the value would be a the substring between two known attributes on both sides, that would be great.
Best answer by fariyafarhad
I decided to use a StringSearcher.
So for that one line, I set up 3 string searchers in series. If the string is matched, this transformer automatically puts the matching text in an attribute and I specified the attribute name. The first StringSearcher is set up this way.
This means one transformer per
attribute. If any one has a better suggestion, still welcome :)
dustin
Forum|alt.badge.img+36
  • Oct 16, 2017 6:02 PM UTC
Here is my first thought. On the StringConcatenator, I put in 4 elements from the list to account for 4 separate 'words' in the Intersection, i.e. Huntsville Browns Ferry Road. You can add more list elements there if you think you would have that scenario.
Hello @cartoscro
I appreciate your answer. That seems like a good way to do it. What I have though are many different lines with the same formatting issue. Using so many transformers per line may be a bit too much. I am trying to see if there is an easier Regex way of doing it.
dustin
  • Oct 16, 2017 6:30 PM UTC
Hello @cartoscro
@fariyafarhad There likely is a cleaner way to do it with Regex. FME is very efficient within it's text string processing, so I have always defaulted to the line of thinking with multiple transformers.
dustin
  • Oct 16, 2017 6:41 PM UTC
Hello @cartoscro
Slightly smaller workflow:
Hello @cartoscro
@cartoscroI like the shorter workflow. Though I think I stumbled upon an answer myself. Thanks!
  • Oct 16, 2017 7:21 PM UTC
  • Oct 16, 2017 9:55 PM UTC
Hi @fariyafarhad, why not use the StringSearcher with this regex?
^Ticket No\s*:\s*(.*)\s+Nearest Intersection\s*:\s*(.*)\s+Seq No\s*:\s*(.*)$
And set the Subexpression Matches List Name (e.g. _sub). You can then rename "_sub{0}.part" to "Ticket No", and so on.
