OffsetCurveGenerator generate gaps within one of the offset multiCurve output lines
  • May 3, 2016 3:39 PM UTC
  • 113 views
juanmahere
Forum|alt.badge.img+15
Hi guys,
I've seen that the transformer "OffsetCurveGenerator" creates me some gaps on one of the offset lines generated.
Here are the parameters set:
The input line from a ESRI Shapefile, which makes the issue (nothing really complex..):
and here is the one on which has been created gaps (PINK) right side, and (BLUE) the Left side with no gaps:
As you see, the other MultiCurve line, well created is the LEFT side from the transformer output. But the RIGHT side (pink) is created with gaps.
I need to say that I tried to isolate that line, and the output stays the same.
I use FME Desktop 2015.1.0.1 - WIN64 - Build 15480.
Thanks for the help,
todd_davis
Forum|alt.badge.img+23
  • May 8, 2016 9:49 AM UTC
You should get the same result with this, but would be good to confirm. So use the FME function caller and add this
 @Buffer(0.000002,22.5, RIGHT_SIDE_ONLY)
 http://docs.safe.com/fme/html/FME_FactFunc/doc_pag...
What are the coordinates of the line?
daveapegg
Forum|alt.badge.img+4
  • May 27, 2020 7:52 AM UTC
Hi Juan, did you end up finding a solution for this? I am having the same issue now on 2019.1
Cheers, Dave.
