Odd behaviour for AttributeFilter, Tester, TesterFilter with Unfiltered values
  • November 22, 2023
  • 7 replies
  • 73 views
galigis
Forum|alt.badge.img+20
Hi All,
I'm facing some odd behaviuor with the AttributeFilter, Tester, TesterFilter. The screenshot below shows that my data includes 'g2a' values in the attribute table but I filters that value in any of the transformers cited above the values doesn't show up?
FME_4
Here is another snapshot of the AttributeFilter (unfiltered) after importing all values From Feature Cache:
FME_5
Why does it go into the Unfiltered values?
Any idea more than welcome 🙂
Thanks
nielsgerrits
Forum|alt.badge.img+64
What is the full value? Does it contain newlines?
galigis
  • November 22, 2023
Thanks @nielsgerrits​ - no new lines that I'm aware of, see below an screenshot of the values:
nielsgerrits
Can you create an FFS of this record zo I can try and reproduce? FeatureWriter --> FFS.
nielsgerrits
Also, what FME version do you use?
galigis
  • November 22, 2023
Thanks - attached a FFS sample with some data
I'm using FME(R) 2022.2.5.0 (20230329 - Build 22795 - WIN64)
Cheers
hkingsbury
Forum|alt.badge.img+67
  • November 22, 2023
Cheers
Its working fine for me in 2022.2.0.0 and 2023.1.1.1.
are you using begins with, contains, or regex to filter?
galigis
  • November 22, 2023
Thanks for looking into it @hkingsbury​ I have just tested in FME(R) 2018.0.1.1 (20180615 - Build 18312 - WIN64) and works fine! i love these bug issues from time to time :). The only thing I can do is upgrading to 2023.
Anyway, thanks for checking guys
