Obtain the degrees between 2 points on FME
  • Oct 25, 2017 9:20 PM UTC
  • 104 views
I need to know how to get the degrees from 2 nearby points
Any help?
Best answer by nathanatsafe
Hi @emorecas thanks for the question!
In FME workbench you can use the AzimuthCalculator to find angles of features. Of course, this won't work for points as we need to know their position relative to each other, so you'll need to use the LineBuilder to connect your points. If you have many points, this may become more complicated. To tackle this problem in more depth would you be able to post some sample data and your expected output?
Thanks!
Nathan
nathanatsafe
Forum|alt.badge.img+9
  • Oct 25, 2017 10:04 PM UTC
Thanks!
Nathan
