Obtain path to database connection file using pythoncaller
  • April 9, 2024
  • 179 views
_jacques_
Forum|alt.badge.img+15
I’m working on a script which copies data from an Esri arcsde geodatabase to a postgis database. I need to know if the table in the arcsde geodatabase is versioned before I run the rest of the script, and I have a pythoncaller which runs something like this (simplified here):
layername = "schema.layerName"
connectionFile = "path_to_connection_file"
arcpy.env.workspace = connectionFile
desc = arcpy.Describe(layername)
isVer = desc.isversioned
feature.setAttribute("versioned",isVer)
self.pyoutput(feature)
Now, I don’t want to type in the path to the connection file manually, but rather obtain it by some function which can collect the data from the list of database connections I entered in the settings.
Is this possible? I’ve looked into the FME Web Services API reference for such a function without any luck.
Best regards,
Jacques 👷🏼
_jacques_
  • April 10, 2024
Found it, here’s for anyone looking for the answer:
import fmewebservices
ncm = fmewebservices.FMENamedConnectionManager()
connection = ncm.getNamedConnection("connection_name")
connection_file_path = connection.getNameValues().get("DATASET")
