Objs to Cesium Ion via Cesium Ion Connector don't have geolocation
  • May 19, 2021
  • 0 replies
  • 23 views
See attachments for my pipeline. In the pipeline I have a simple 3dmodel and a some amount of random generated points in a certain area where to populate that model to. The pipeline seems to work all the way to the end. If I inspect it in FME, everything is in correct place on the map, but once I send the obj to Cesium Ion, it no longer has the geolocation data, and it wants me to place it by hand in the Cesium Ion Portal. Any idea what might be wrong?
If I open the obj that I just generated again in the FME Desktop, it shows the models on map correctly.
Screenshot 2021-05-19 123945
https://cesium.com/docs/tutorials/import-3d-models/
