Null Geometry
  • August 22, 2013
  • 585 views
I'm using FME 213 SP3.
How can test for NULL geometry?
Thanks
Best answer by conterrastefan
my first idea is to use the GeometryFilter here one output port is NULL.
Another approach is to expose the fme_type attribute and use the Tester -> fme_typer = fme_no_geom
Best regards,
Stefan
Best regards,
Stefan
gmbutler2
Forum|alt.badge.img+10
  • June 27, 2016
@petejnr What I do is I put a Deaggregator after the reader, then I add a GeometryFilter and draw a connection from every possible geometry over to a writer. Then I run it and see what all types of geometries are associated to that reader object.
