Not listExploder json result{}
  • Nov 7, 2017 3:55 PM UTC
  • 73 views
dbklingdom
Forum|alt.badge.img+7
Why can't ListExploder see result{} from a reader that reads json with the output of result type array?? I have tried jsonFragmenter but listExploder still does not see result{}.
dbklingdom
  • Nov 7, 2017 3:56 PM UTC
in FME 2016
jdh
Forum|alt.badge.img+41
  • Nov 7, 2017 3:57 PM UTC
Did you expose result{} on the JSONFragmenter?
dbklingdom
  • Nov 7, 2017 4:30 PM UTC
Yeah thanks for the reply. Since in Parameters I am able to pick result I though it was exposed. When I set it to result{} it droppers out to rejected. with out {} listExploder can't see results.
  • Nov 7, 2017 9:54 PM UTC
Take a look at detail of the feature that is output from the JSONFragmenter with the Logger or Inspector. Does the list "result{}" have been created actually? Perhaps isn't the list name "arrray{}"?
