Noobie: convert rd coordinates too gps WGS84 coordinates
  • Apr 4, 2019 6:33 PM UTC
  • 5 replies
  • 423 views
Hallo everybody,
This will be my first model. I have seen the power of FME and i want too learn it.
My first problem that i want to solve in FME is;
i have a excel file contains x,y rijksdriehoek coordinates i want to convert it too gps location.
Can somebody help me with a model or tell me what handler i can use to get the desire results.
The output should be a column with gps coordinates in excel.
Thank you for your time and help
Greets,
Charaf from the Netherlands
erik_jan
Forum|alt.badge.img+26
  • Apr 4, 2019 7:09 PM UTC
The transformer you want to look at is: AttributeReprojector.
Both RD and WGS84 Lat Long are available in the list.
  • Apr 4, 2019 8:07 PM UTC
Thank you, it did exactly what the handler said. the result is 2 columns where the x, y coordinate are replaced.
my model exist out of a reader-AttributeReprojetor-writer.
To get the desired output i like to add the converted columns in the original file so that the relations between the other columns still exist.
Any suggestion @erik_jan?
erik_jan
  • Apr 4, 2019 8:11 PM UTC
Use a Reader.
Then an AttributeCreator to create attributes Lat and Long as copies of X and Y.
Use the AttributeReprojector on the new attributes Lat and Long to convert those values and keep the X and Y unchanged.
The write all existing, plus the Lat and Long out using the writer.
  • Apr 5, 2019 8:51 AM UTC
Thank you @erik_jan. i got the desired results.
The only thing that i still trying too solve is that the writer inspector not visualizing the coordinates.
"There is no geometry in this View." maybe you got the answer also for this problem. i know its a different topic. i use the trial for arcgis.
Thank you for helping me make my first model ever.
I hope i don't get the FME fever. lol
Greetings,
Charaf
Forum|alt.badge.img+54
  • Apr 5, 2019 8:54 AM UTC
Greetings,
Charaf
The coordinates only exist as attributes, if you want to see points you will need a VertexCreator to create points from your reprojected coordinates
