No Schema found, features written using SQLCreator w/ MSSQL_ADO
  • May 9, 2016
  • 102 views
I am trying to create a simple read/write workspace using SqlCreator to access an MS SQL database.
When I run the workspace, the inspector shows an empty table with header <no schema> above a single column of 928 rows (the expected # of resulting rows).
When I click on an individual cell in the table, the feature information pane displays the expected feature properties and attributes. Again, no attributes are displayed in the table itself.
When I point the SqlCreator results to a csv writer, the log shows that all features were written, but the output CSV is empty.
I have verified that Native Client 2012 is installed. Any advice is appreciated!
Posting the last bit of the log file here:
Microsoft SQL Server Non-Spatial Reader: Database read complete. Retrieved 928 feature(s)
SQLCreator_Creator(CreationFactory): Created 1 features
Microsoft SQL Server Non-Spatial Reader: Closing `KITSDB' . Read operation complete
SQLCreator RESULT Splitter(TeeFactory): Cloned 928 input feature(s) into 2784 output feature(s)
SQLCreator_RESULT_0_Xo1c2GgqDQQ= Feature Counter -1 3(TeeFactory): Cloned 928 input feature(s) into 928 output feature(s)
SQLCreator_RESULT_1_Xo1c2GgqDQQ= Feature Counter -1 5(TeeFactory): Cloned 928 input feature(s) into 928 output feature(s)
SQLCreator_RESULT_2_Xo1c2GgqDQQ= Feature Counter -1 8(TeeFactory): Cloned 928 input feature(s) into 928 output feature(s)
SQLCreator_Result_DirCreator(CreationFactory): Created 1 features
SQLCreator_Result_DirCreatorCleanerUpper(TeeFactory): Cloned 1 input feature(s) into 0 output feature(s)
SQLCreator_Result_FeatureDirector(TestFactory): Tested 928 input feature(s) -- 0 feature(s) passed and 928 feature(s) failed
SQLCreator_Result___FeatureDirector1(TestFactory): Tested 928 input feature(s) -- 0 feature(s) passed and 928 feature(s) failed
SQLCreator_Result_VectorSetterUpper(TeeFactory): Cloned 928 input feature(s) into 928 output feature(s)
SQLCreator_Result___PointCloudThinner(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
SQLCreator_Result_RasterSetterUpper(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
Stored 928 feature(s) to FME feature store file `C:\\Users\\xxxxx\\AppData\\Local\\Temp\\intersection_status_v1_162252\\inspector.ffs'
Saving spatial index into file 'C:\\Users\\xxxxx\\AppData\\Local\\Temp\\intersection_status_v1_162252\\inspector.fsi'
Finished saving spatial index into file 'C:\\Users\\xxxxx\\AppData\\Local\\Temp\\intersection_status_v1_162252\\inspector.fsi'
Stored 1 feature(s) to FME feature store file `C:\\Users\\xxxxx\\AppData\\Local\\Temp\\intersection_status_v1_162252\\inspector.fsc'
SQLCreator_Result_Recorder(RecorderFactory): Recorded 928 feature(s) to file `C:\\Users\\xxxxx\\AppData\\Local\\Temp\\intersection_status_v1_162252\\inspector.ffs'
SQLCreator_Result_2_Logger(TeeFactory): Cloned 928 input feature(s) into 928 output feature(s)
SQLCreator_Result_2 LOGGED Output Nuker(TeeFactory): Cloned 928 input feature(s) into 0 output feature(s)
Destination Feature Type Routing Correlator(RoutingFactory): Tested 928 input feature(s), wrote 928 output feature(s): 0 matched merge filters, 928 were routed to output, 0 could not be routed.
Final Output Nuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
f_20(CreationFactory): Created 1 features
f_21(TeeFactory): Cloned 1 input feature(s) into 0 output feature(s)
Feature output statistics for `FFS' writer using keyword `W_1':
Features Written
Total Features Written 0
CSV Writer: Closing file `C:\\Users\\xxxxx\\Desktop\\test_csv_writer.csv'
Feature output statistics for `CSV' writer using keyword `CSV_1':
Features Written
test_csv_writer (test_csv_writer) 928
Total Features Written 928
Features Read Summary
Total Features Read 0
Features Written Summary
test_csv_writer 928
Translation was SUCCESSFUL with 0 warning(s) (928 feature(s) output)
Stored 20 feature(s) to FME feature store file `H:\\ATD_BSA\\Intersection Status\\FME\\intersection_status_v1_log.ffs'
FME Session Duration: 1.8 seconds. (CPU: 0.3s user, 0.3s system)
END - ProcessID: 7592, peak process memory usage: 63636 kB, current process memory usage: 63320 kB
Best answer by takashi
Hi @johnc, the Table View of Data Inspector will not display attributes which are not exposed on the Workbench Canvas. The SQLCreator will not expose attribute (field) names automatically, so you have to expose them via the "Attributes to Expose" parameter. Also you may have to configure User Attributes in the CSV writer feature type to define how to map the source attributes (from SQLCreator) to destination attributes (to CSV table).
  • May 10, 2016
  • May 10, 2016
Wow, that was easy. Thanks @takashi!
