No output with Shortest Path
  • Aug 9, 2018 8:17 AM UTC
  • 11 replies
  • 279 views
fmenco
I'm trying to create a shortest path from point A to B, yet FME is not outputting any path. I've looked at similar questions asked on here, and I've adapted my workbench accordinly, but still no luck.
I'm using an OpenStreetMap highway layer as input. I've explicitely set my snapping tolerance as relatively high in the shortespathfinder, just so that I could just get some output. But it didn't work either.
Printscreen of my workbench:
Best answer by david_r
For some reason I've had much better results using a stand-alone Snapper before building the topology, rather than relying on the ShortestPathFinder tolerance.
  • Aug 9, 2018 8:24 AM UTC
Weren't no features output from the "NoPath" port?
If all network lines don't belong to a single connected network, there could be no path between specified from-to. You can use the NetworkTopologyCalculator to check if the lines belong to a single network.
  • Aug 9, 2018 8:27 AM UTC
fmenco
  • Aug 9, 2018 8:31 AM UTC
All the features are output through the unused port. There's also one output though the nopath port, which is just the from-to line. And of course the from-to also outputs the line I created with the creator transformer
fmenco
  • Aug 9, 2018 8:38 AM UTC
Yes, this worked... Thank you !
owen
  • Aug 9, 2018 11:55 AM UTC
Not helpful, but I wouldn't try routing with Open Street Map....
fmenco
  • Aug 9, 2018 11:56 AM UTC
Thanks.... why not? Because of the quality?
owen
  • Aug 9, 2018 4:00 PM UTC
Yes, its not designed for routing so you might get some odd results
fmelizard
Forum|alt.badge.img+22
  • Aug 9, 2018 5:34 PM UTC
@david_r Snapping within the ShortestPathFinder is only for snapping "points of the From-To line to the closest end points of the Network lines". Snapping From-To points to segments isn't possible yet and the ShortestPathFinder needs a clean network for input.
fmenco
  • Aug 10, 2018 6:29 AM UTC
Thank you!
And how would this whole "shortest path finder" process with the same parameters (by lenght, by costs etc) be accomplished with raster data?
@takashi
@david_r
@owen
@DanAtSafe
  • Aug 10, 2018 6:58 AM UTC
Thanks for clarifying, I should've had another coffee before before writing that answer :-)
fmelizard
  • Aug 10, 2018 6:22 PM UTC
Thank you!
@takashi
@david_r
@owen
@DanAtSafe
@fmenco You'd have to convert the raster data to vector first - the ShortestPathFinder only accepts line features.
