Nested JSON array to SQL table
  • Oct 3, 2018 10:16 PM UTC
  • 5 replies
  • 397 views
ayraju
I am using FME to extract API data and pull the JSON string into a SQL table. I am able to work with most of the tables but there are a couple of them that are nested and am having trouble getting to format properly.
I have attached how the results need to look and sample of the JSON results
I tried using JSON Fragmenter but i cannot get the results. Can someone advise the best way to get this.
Best answer by takashi
Hi @ayraju, basically you can use multiple JSONFragmenters to extract every content from each level in a nested JSON document.
However, according to the desired result table shown in your screenshot, the requirement is to extract keys of the JSON "fields" objects in the lowest level as attribute values. This isn't usual JSON flattening operation.
I would provide two different approaches to resolve the special requirement. One is using regular expression (StringSearcher), another is using XQuery (JSONiq extension) expression (XMLXQueryExtractor).
See these workspace examples. Both are created with FME 2018.1.0.2.
mygis
Forum|alt.badge.img+14
  • Oct 4, 2018 12:36 AM UTC
Hi @ayraju can you share the link with us if it is public?
  • Oct 4, 2018 7:37 AM UTC
ayraju
  • Oct 4, 2018 4:34 PM UTC
Wow, you are amazing. This is great. Thank you so much!
f.kemminje
Forum|alt.badge.img+11
  • May 28, 2019 2:25 PM UTC
@takashi I was just going thru the answers for my current Question, i got your answer . similar to this answer.
what if the json objects are dynamic. i mean if the geometry objects(geojson) and stored in nested arrays. and json query string is different for each geometry. in my case there are many geometries are stored inside json file. and not in one location, all are in different nested arrays.
How can we extract all the geometries from different nested arrays?
nampreetatsafe
FYI: An answer to @fkemminje's question was provided here:
