NeighbourFinder not working well on Form 2023.0.0.1
  • February 27, 2024
  • 49 views
noe
Participant
Hi FME Community,
I’ve been testing out an old script with FME Form 2023.0.0.1 and noticed one workspace with NeighbourFinder transformer has come to a halt with no clear message of warning or error. The same workspace works well with older FME Desktop Workbench 2022.1. Data size is around 50K rows, however it’s unclear at what progress/rows the halt would happened.
I was suggested to upgrade to newer version, anyone encounter similar experience?
Cheers,
Noe
DanAtSafe
Forum|alt.badge.img+22
  • February 27, 2024
@noe You could try FME 2023.12023.2 or 2024.0 beta to see if the problem has been fixed, or submit a case with your workspace and sample data at https://support.safe.com/s/submit-case for us to investigate.
noe
Participant
  • Participant
  • March 4, 2024
Thanks @DanAtSafe, I can confirm that upgrading to FME Form 2023.2.2 solved the NeighborFinder issue.
