NeighborFinder error
  • Sep 19, 2019 6:06 AM UTC
  • 8 replies
  • 162 views
rakeshreddy0996
Error details:
NeighborFinder_<Rejected>(TeeFactory): NeighborFinder_<Rejected>: Termination Message: 'NeighborFinder output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
please suggest best solution
Regards: Rakesh
Best answer by danullen
You probably have some features without geometry coming in as either Candidate or Base. Please check that your inputs are ok.
  • Sep 19, 2019 6:53 AM UTC
rakeshreddy0996
everything perfect but again, I'm getting same issue
is there any alternate
please suggest
itay
Forum|alt.badge.img+19
  • Sep 19, 2019 8:08 AM UTC
You can open the rejected features (if using caching) and have a look at the rejection reason, what does it say?
please suggest
Then I'd suggest what FME suggests. :-) Which is to go to the Navigator and change Workspace Parameters > Translation > Rejected Features to "Continue Translation" to see if it's just one or a few features that are rejected or if everything is rejected.
  • Sep 19, 2019 8:44 AM UTC
please suggest
Alternatively you can simply connect an Inspector to the <Rejected> port of the NeighborFinder and look at what comes out, it may even contain an attribute with an error message. That way you won't have to change any workspace-wide behavior.
See also the reply from @itay
itay
  • Sep 19, 2019 8:59 AM UTC
Yes all rejected ports have am fme_rejection_code attribute which is very useful for debugging.
gio
Forum|alt.badge.img+15
  • Sep 19, 2019 11:56 AM UTC
@rakeshreddy0996
This error occurs when using a groupby and it receives objects without the used groupby attribute.
..which you can see if you check which object(s) cause the error.
Often the relevant ffs in your ..fme\\temp folder (check the code in the error message) can be opened (when the rejection code doe not say anything, which is often the case.
rakeshreddy0996
I think error may get for below reason
Bases and candidates both having same header names
plz suggest
