Need to compare two values in two separate tables
  • Mar 12, 2024 12:22 AM UTC
  • 155 views
vxn43
Forum|alt.badge.img+20
I have two Excel Files. You can see from the screenshot, in the Visual Preview, I need to compare 95137 and 95138 in a Tester. Before I can do this, I need to “move” 95137 to row 1 (highlighted in yellow in the screenshot below) and have only one row in the table not two, what is the best way to make this happen?
Best answer by ctredinnick
You’re wanting to use an Aggregator, aggregate attributes only, and have it set to Merge Attributes. That’ll flatten it to one feature, and resulting attributes will be from any input feature which had a value there.
ctredinnick
Forum|alt.badge.img+22
  • Mar 12, 2024 12:53 AM UTC
