Hello,
here is what I am trying to do in a workbench that is attached here:
1) Input data are .xyz file with a list of 3D point coordinates, jpg + jgw files with DEM photo
2) I need to create surface TIN + set an appearance to it
3) I need to export it into a format that Trimble Connect is able to process.
(https://community.trimble.com/viewdocument/supported-files) - There is a list of 3D supported formats
The problems that I run into:
1) Data need to have a defined coordinate system.
1) I need to create a FME Cloud app, where customer is able to run this transformation themselves.
2) The formats that Trimble Connects do not support textured surfaces / solids
3) FME Cloud does not support many writers that Trimble Connect would be able to process
DGN - FME is unable to write 3D solids (only extrusions, which is not what I need) or meshes, all dgn files that I try to create are after loading simple lines.
https://community.safe.com/s/question/0D54Q000080hfr8/dgn-writer-outputs-lines-instead-of-surface
DWG 2018 - no coordinate system, 3D data only in realdwg - cloud does not support this
DXF - same as above
IFC - as far as I know no coordinate system support
IGS - no FME support
LandXML - Trimble Connect and I believe even FME support only version 1.2 - no textures support
Navisworks - no FME support
Revit - FME Cloud does not support
SKP - FME Cloud does not support
STEP AP203 and AP214 - to be honest no idea here
TC ZIP, TEKLA, TRB - no support
I think that my process si pretty much finished, I am stuck on using a writer that Trimble Connect can read and FME Cloud write. Every tutorial on how to solve this scenario writes in 3D pdf...
https://community.safe.com/s/article/point-clouds-and-surface-modelling
https://community.safe.com/s/article/point-cloud-to-3d-terrain-model-with-buildings-dwg
