Need Fme Parameter Value/Fme Attribute Value Inside End Python Script
  • Jun 20, 2018 2:29 PM UTC
  • 8 replies
  • 166 views
f.kemminje
Forum|alt.badge.img+11
Hi Fme team,
After completion of fme script, i need to run sql query for the resultant destination table. So I am running sql thru end python script. And for this sql query I need one variable(fme published parameter or fme attribute)
from jest ran fme script. is there any way i can get value from fme published parameter into end python.
pls help.
Best answer by david_r
The Oracle Spatial Object writer does indeed have the "SQL to run after writer" setting:
You can reference published parameter inside it using $(PARAMETER_NAME) notation.
  • Jun 20, 2018 2:40 PM UTC
Which writer are you using?
Some writers have a setting for an SQL command to execute after the writer terminates, have you looked into that?
  • Jun 20, 2018 2:41 PM UTC
You can access published or private parameters in any Python code using the FME_MacroValues dictionary, e.g.
my_value = FME_MacroValues['MY_PUBLISHED_PARAMETER']
f.kemminje
  • Jun 20, 2018 2:44 PM UTC
does it work inside shutdown Python script ?
f.kemminje
  • Jun 20, 2018 2:45 PM UTC
@david_r
i use oracle spatial writer, And i am running shutdown python script.
can i access FME_MacroValues inside shutdown python?
  • Jun 20, 2018 2:54 PM UTC
It works in any Python code, so yes, it also works in the shutdown script.
  • Jun 20, 2018 2:56 PM UTC
f.kemminje
  • Jun 20, 2018 3:33 PM UTC
@david_r
One quick question,
Calling python function inside shut down python script is not working for me?
for example
import fme
import fmeobjects
make_a_sound()
def make_a_sound():
    print('quack')
Python Exception <NameError>: name 'make_a_sound' is not defined
Error executing string `import fme
its giving error
  • Jun 20, 2018 3:48 PM UTC
@david_r
One quick question,
for example
import fme
import fmeobjects
make_a_sound()
def make_a_sound():
    print('quack')
its giving error
Python scripts (like most programming languages) are interpreted top-down, meaning that you must put the declaration of "make_a_sound" before you call it, e.g.
def make_a_sound():
    print('quack')
make_a_sound()
