Need easy way of calculating/exporting min/max width of polygon
  • Jan 7, 2016 8:56 PM UTC
  • 29 replies
  • 1174 views
Show first post
davideagle
Forum|alt.badge.img+21
  • Jan 18, 2016 10:18 AM UTC
Unfortunately I also don't know how you can use the ArcGIS Python function in FME workspace.
I upgraded my previous solution. The attached workspace is not perfect, but generates "better" cross sections for some areas as shown in this image. estimate-river-cross-sections.zip
The key point is how to create "clean" center line for the river area, and the Generalizer might be useful in this case. However, the best solution could be different depending on the actual data condition. As @rollo mentioned at first, I think you cannot avoid doing trial and error approach to find appropriate solutions for each area. Good luck!
Excellent work
  • Jan 18, 2016 3:08 PM UTC
Extension. I published a custom transformer named BoundsSplitter in the FME Store. It implements the algorithm similar to the ArcGIS python function ;)
  • Jan 19, 2016 11:35 PM UTC
Yes, thank you for the best FME solution to this problem. I appreciate all your efforts. Hopefully I can buy you a non-trivial beverage some day.
Best,
Pete
  • Oct 18, 2019 3:05 PM UTC
Many thanks for this Takashi - I managed to adapt the workspace for us to calculate minimum widths of our roadside nature reserves - invaluable!
Best wishes,
Jane
