My PV stations are in netherlands, I have their coordinates but in fme which coordinate system should I choose LL84 or netherlands specific (like EPSG..., Netherlands R..)?
  • Oct 23, 2017 3:02 PM UTC
  • 9 replies
  • 94 views
Best answer by redgeographics
Right, that's lat/lon. LL84 in FME.
daveatsafe
Forum|alt.badge.img+24
  • Oct 25, 2017 5:41 PM UTC
Hi @hassangillani3,
It will depend on what coordinate system your coordinates are in.
If the easting values are around 5 or 6, then you most likely have lat/long coordinates. If the values are much larger, then you have coordinates from one of the projected coordinate systems.
Determining which datum your coordinates are in (Amersfoort or WGS84) is not possible from just the coordinate values.
What is the source of your coordinates? Was there any metadata specifying the coordinate system?
Forum|alt.badge.img+63
Yes, if you can show us the coordinate values we should be able to figure out which of the systems they're in.
lars_de_vries
Forum|alt.badge.img+10
If the coordinates are in RD (X < 150.000 and Y > 300.000) then I would use the EPSG:28992
Thank you
My source of coordinates is from PVoutput website (I got it from its HTML code)
Kindly guide further
Thank You
Thank you
Thank You
Can you post the actual coordinates here? (just one xy pair will be enough)
Thank you. Kindly find my coordinates located in Netherlands (Amsterdam)
latitude = 5.286193
longitude=52.1182925
source: pvoutput.org; station id =35087
latitude = 5.286193
Now kindly tell which should I chose from above options in picture attached.
Thanks again
latitude = 5.286193
