my datum definition has an error ?
  • October 27, 2013
  • 5 replies
  • 44 views
I  reproject  a dwg file  using reproject transformer  from a beijing datum to a WGS84 datum, I used  BURSA  approximations.I'm  sure the  seven  parameters  is correct because  I'v  verified  these in arcmap . I defined  the datum  and the coordinate system  like  below in mycoordsysdefs.fme
#DATUM_DEF Beijing1954 \\
#   DESC_NM “LocalTranstoWGS84” \\
#   SOURCE “me” \\
#   ELLIPSOID KRASOV \\
#   USE BURSA \\
#   DELTA_X -1200.73773931196236 \\
#   DELTA_Y 270.135884745262 \\
#   DELTA_Z -870.732624966858 \\
#   BWSCALE 41.6212793541839  \\
#   ROT_X 0.345260849        \\
#   ROT_Y 4.031002029         \\
#   ROT_Z 0.280361064
from the  name list  of  coordinate system gallery  ,I can saw the COORDINATE_SYSTEM_DEF  I defined ,but  the part  info  like this
ESRI WKT Description
GEOGCS["Unknown",DATUM["D_Unknown",SPHEROID["Unknown",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
1. why the datum and GEOGCS is unknown in esri wkt description ?  I defined them  following the the syntax of definitions  in mycoordsysdefs.fme  .
2. the transform result  is out of position about 1 second.  why?
can anybody  help me ? thanks in advance.
  • October 27, 2013
Hi Alice, Maybe FME ignores the line that starts with # as a comment...
  • October 27, 2013
thank you reply
in fact , At first  I put the definitions in  LocalCoordSysDefs.fme  without  #  , but  the result  is the same as above.
  • October 27, 2013
my  COORDINATE_SYSTEM_DEF  use  fme predefined  definition:  Bjing54.GK3d/CM-117E
from the  name list  of  coordinate system gallery  , the  definition of  Bjing54.GK3d/CM-117E  is as  below:
CS_NAME: Bjing54.GK3d/CM-117E
DESC_NM: Beijing 1954 / 3-degree Gauss-Kruger CM 117E
DT_NAME: Beijing1954
GROUP: ASIA
MAP_SCL: 1
PARM1: 117
PROJ: TM
QUAD: 1
SCL_RED: 1
SOURCE: EPSG, V6.6, 2436 [EPSG]
UNIT: Meter
X_OFF: 500000
ZERO_X: 0.0001
ZERO_Y: 0.0001
with the datum definition  and  CS  definition  , I don't  know how  to  fix  them  to  get  the  correct  transform  results .
  • October 27, 2013
Do you perhaps want to modify the definition of predefined datum named Beijin1954?
DATUM_DEF is used to define a new datum, I don't think it can modify predefined one. If you need to modify predefined datum, try defining DATUM_DEF with other name as a new datum.
  • October 28, 2013
thank you ,I'v  solved  the problem
