Multipolygons to Polygon
  • Mar 4, 2013 4:37 PM UTC
  • 18 replies
  • 2091 views
Is there any transformers to aid in  MultiPolygons to simple Polygons.
I'm going from ESRI Geodatabase to SDF.
Chris
fmelizard
Forum|alt.badge.img+22
  • Mar 4, 2013 4:43 PM UTC
how about the deaggregator?
davideagle
Forum|alt.badge.img+21
  • Mar 4, 2013 4:45 PM UTC
You'll need to consider using the Deaggregator transformer to break your polygon groups into unique entities. Though make sure you retain your ID number or use a Counter to create one first as you may later wish to know which Multipolygon your unique polygon came from...
jnotter
Forum|alt.badge.img+7
  • Jan 22, 2020 11:13 PM UTC
Even after using a Deaggregator and Tester I still get multiple identical polygons inside of my GeoJSON rendered multi-polygon geometries. I want them to come out as single polygons rather than multi-polygon.
oscard
Forum|alt.badge.img+23
  • Jan 23, 2020 3:03 PM UTC
Could you share a sample of that GeoJSON?
jnotter
  • Jan 23, 2020 3:10 PM UTC
grid.json see attached sample. If trimmed to eliminate duplicates this 792 kB file drops to less than 20 kB.
Forum|alt.badge.img+63
It looks like they're all the same. So your multipolygon consists of a lot of identical polygons. Deaggregating those will indeed give you a lot of identical polygons.
You can use a Matcher to remove duplicate geometries.
oscard
  • Jan 23, 2020 3:20 PM UTC
Yes, every feature is formed by the same polygon several times. After the Deaggregator you could also use a DuplicateFilter for "fme_feature_type"
jnotter
  • Jan 23, 2020 8:18 PM UTC
I tried matcher for single match and unmatched and still got the multies. I have deaggregator in line but it does not remove them. Now I am curious: Duplicate Filter _after_ Deaggregator seems to be filtering them out, but not before, but even then... not all of them. Still getting multiples.
  • Jan 23, 2020 10:13 PM UTC
Deaggregate first, and then filter out duplicates with the Matcher.
jnotter
  • Jan 23, 2020 11:34 PM UTC
Matcher has not produced sufficient removal of identical.
Forum|alt.badge.img+54
  • Jan 24, 2020 6:48 AM UTC
If you are confident all the geometries are identical, you could use a tester after the deaggregator to test for part_number = 0.
bwn
Forum|alt.badge.img+26
  • Jan 24, 2020 7:05 AM UTC
@jnotter, to come at this another way: Have you considered using Dissolver? Feed it the aggregate features (ie. Don't use Deaggregator with this method). This will deaggregate the polygon aggregates within the Transformer and merge all overlapping parts into a single polygon. It is somewhat more processor intensive, but it should deal with the fact that some of your multi-polygons aren't quite equal to each other by dissolving the small differences.
  • Jan 24, 2020 1:13 PM UTC
I think the combination of Deaggregator and Matcher works fine.
The workflow generates 20 rectangular polygons independent each other. Isn't this your desired result?
  • Jan 24, 2020 1:16 PM UTC
I agree, the solutions suggested here all give me the same 20 single polygon output
jnotter
  • Jan 24, 2020 3:17 PM UTC
Key question, @takashi, in the back-end data are there duplicates or are you just getting exactly these 20 polygons without overlap of identical?
jnotter
  • Jan 24, 2020 3:19 PM UTC
@bwn, For my purposes each block of the grid must be thematically independent (for color thematic application) of the others, so dissolving into single feature across multiple polygons takes away this capability. The multi-polygons each are a set of identical coordinates, so there are no small differences to tolerate/adapt.
bwn
  • Jan 25, 2020 2:32 AM UTC
Dissolver is typically used with the "Group By" attribute set that ensures that it only dissolves polygon(s) that are part of that group. Since each grid block has its own Name ID, then this can be used to group them and a single polygon feature would be output for each Grid ID.
It Matcher is not removing all the duplicates, this infers that the geometries are not precisely the same, which can happen with data created outside FME due to outside applications not always creating and storing geometry data with absolute precision. Although noting that the test by @takashi on the sample data below indicated that at least in the sample data provided, Matcher works in this case.
  • Jan 25, 2020 2:51 AM UTC
There are 20 single polygons, no duplicates. If you still have any problem even if you use the combination of Deaggregator and Matcher, please share your workspace which reproduces the problem.
