Multiple Spatial Predicates in SpatialRelator in DE-9IM
  • Feb 8, 2019 3:05 PM UTC
  • 98 views
I have been able to run SpatialRelator with one DE-9IM string representing one matrix. In this simple case I used a text User Parameter. I have expressed the relation Within as the text T*F**F***
Now, I want to test whether Requestor is CoveredBy Supplier. This is a generalization of the relation Within and can be expressed in DE-9IM with 4 matrices, see https://en.wikipedia.org/wiki/DE-9IM#Spatial_predicates
T*F**F***
*TF**F***
**FT*F***
**F*TF***
I don't understand what I should provide to SpatialRelator. A list of strings? a longer string?
Any idea?
Best regards
Forum|alt.badge.img+54
  • Feb 8, 2019 3:34 PM UTC
I believe you need a space separated string
T*F**F*** *TF**F*** *TF**F*** **F*TF***
  • Feb 11, 2019 7:46 AM UTC
It seems it works. The string is: T*F**F*** *TF**F*** **FT*F*** **F*TF***
Thank you @egomm
