Multiple Selection in the ListConcatenator tranformer
  • November 23, 2023
  • 46 views
galigis
Forum|alt.badge.img+20
Hi All,
I'm working on a workflow to bring the information from 3 separate layers into my analysis output. SpatialRelator would do the work but also want to create the lists in order to concatenate values into the same cell. I need to concatenate different fields but ListConcatenator only allows one at time,
Screenshot below shows the fields I want to concatenate with the following structure:
  • ListConcatenation A = GM_SiteRef + GM_Type
  • ListConcatenation B = LandOwner + LandOwnership_Status + LandOwnership_TITLE_NO
  • ListConcatenation C = LEP_Site
FME_6How can I make it to work and have multiple ListConcatenators? I'm trying to avoid any filter or tester as won't work....
PD: I would also need to add a ListDuplicateRemover before the concatenator to avoid duplicates in the same cell.
Thanks in advanced 🙂
  • November 23, 2023
Hi @galigis​ ,
For exmaple, assuming
_relationships{}.GM_SiteRef contans three elements: "a", "b", "c"
_relationships{}.GM_Type contains three elements: "x", "y", "z"
In the case, is "a,b,c,x,y,z" (i.e. concatenated all the elements in the two lists) your expecting result?
galigis
  • November 23, 2023
Thanks @Takashi Iijima​ - I think I have fixed the issue...partially 😞
I have added all the ListConcatenator transformers one after the other and seems to work...but now I can't remove the duplicate lists, see below:
FME_8 How can I remove those duplicates (e.g. Natural Land, Natural Land, Synergy, Synergy) in the same cell? I tried already ListDuplicateRemover before and after the concatenation but no luck
Cheers
galigis
  • November 23, 2023
Sorted now with the following workaround:
1- ListConcatenator
2- AttributeSplitter
3- ListDuplicate
4- ListConcatenator
