I'm having problems using the Clipper transformer with 19 las point clouds as the input / clipee and a MapInfo tab file as the clipper, with the output being written as LAZ files. The workspace works fine if I just run it in isolation, as shown below:
However, in addition to the output from the Inside port of the "OSTile_Clipper" being written as a series of LAZ files, I also want to put this output this through a 2nd clipper (ControlSurfaceClipper) as the Clippee and have it clipped against another MapInfo tab file.
On enabling the ControlSurfaceClipper tranformer and it's associated Clipper input port, all outputs from the 1st transformer are now output via the "Outside" port and no data is output, as shown below:
How do I get around this, so when all transformers & writers are enabled, the data from the 1st Clipper transformer is output via the Inside port?
Below are the parameters for each clipper:
Thanks in advance!
