Multiple Centroids
  • November 20, 2016
  • 6 replies
  • 82 views
arthy
Forum|alt.badge.img+8
Hi all,
I have a dgn file and I'm trying to build the following algorithm
(1) form polygons using selected levels of the dgn file
(2) check the number of centroids inside polygons
(2.1) add a centroid when there is no centroid inside the polygon
(2.2) if multiple centroids are inside a polygon, change the level of those centroids.
How can I achieve the step 2.2.?
arthy
  • November 20, 2016
itay
Forum|alt.badge.img+19
  • November 20, 2016
Hi @arthy, would be helpful if you can post some data next to your workspace. Sp that ppl can have an idea what they are dealing with.
arthy
  • November 20, 2016
@itay,
Here is the workspace that I produced rajout-centroide-igds2igds.fmw and also a file test.dgn to test as you requested.
itay
  • November 20, 2016
@itay,
Hi @arthy, the thing about dgn is that you cant update the level so writing a new dgn is the only option.
Have a look at the attached workspace for a possible solution.
multiple-centroids.fmw
Hope this helps
mark2atsafe
Forum|alt.badge.img+59
  • November 21, 2016
That looks OK to me. Just add an AttributeManager attached to the Tester:Passed port, that sets igds_level to a new value
arthy
  • November 22, 2016
Hope this helps
@itay,
Thanks Based on your suggestions, I edites my workspace and I was able to get my results.
