Multiple AutoCAD layers to one MapInfo table
I have a AutoCAD file that is incorrectly georeferenced. Is there a way to translate the .dwg so that the result is only one MapInfo table? I've done the "Quick Translation" and I end up with 92 different MapInfo tables. I'd like be able to have just one layer that I can "select all" from and drag to the correct (relatively) location. Is there a way to do this?
