Multiline to donut
  • Jul 29, 2019 9:13 PM UTC
  • 69 views
lazarlubomir
Forum|alt.badge.img+11
Hello everybody,
please, has anybody idea how to create from multilines polygon with holes (donut)?
Feature below is composed by many lines, but I need to convert them to single donut.
I also attached data sample of this feature.
Thank You so much!
Lubo
fmelizard
Forum|alt.badge.img+22
  • Jul 29, 2019 9:36 PM UTC
Hi @lazarlubomir You just need an AreaBuilder. 'Aggregate Handling' should be set to 'Deaggregate' by default and 'Create Donuts' should be checked. If you want the holes to be dropped then set that also.
  • Jul 29, 2019 9:51 PM UTC
Just be aware the source geometry contains many degenerated lines which have only one vertex. The AreaBuilder routes them to the <Rejected> port, so you will have to connect an object (e.g. Junction or Logger) to the <Rejected> port, or set Continue Translation to the Rejected Feature Handling parameter in the workspace.
lazarlubomir
  • Jul 30, 2019 12:27 PM UTC
Hello @danatsafe , @takashi ,
thank You so much for Your advice! It works. Anyway, this feature is from Revit file and I have met many problems with reading geometries. E.g. Feature geometry is very often composed by multilines, but they should represent GIS entity - wall, windows, doors etc. So very often FME reads feature as aggregate of lines, check below:
But, my question, is there any possibility, how to create from this aggregate one big polygon copied shape of aggregate? Or six smaller polygons copied all closed parts of aggregate?
I attach data sample of this aggregate.
sample.zip
Thank You so much for ideas!
Lubo
  • Jul 30, 2019 2:56 PM UTC
If you need to create six polygons from the multiline, split the lines at intersection nodes with the Intersector and then apply the AreaBuilder. Then, you can also use the Dissolver to merge the six small polygons adjoining into a single large polygon, if necessary.
