Moving transformers from other workspace
  • October 12, 2016
  • 46 views
I've been thinking if its possible somehow to "drag" your transformers with its settings to other workspace from other workspace?
Meaning that if I would have attributecreator where is for example bunch of attributes what I want to use in other workspace too. Is there way to get this transformer moved to other workspace without losing those settings?
Could sometimes save some time if this would be possible with some "drag and drop" function.
  • October 12, 2016
Hi @a7, you can copy (or cut) and paste transformers from a workspace to another. Select one or more transformers on the Canvas, right-click, and select "Copy" (or "Cut") command.
itay
Forum|alt.badge.img+19
  • October 12, 2016
Next to those options you can select a group of transformers (all within one bookmark) by right click on the bookmark > select all objects in bookmark and then copy paste in the other workspace.
  • October 13, 2016
Wow.. How did I miss that. Thank you very much @takashi and @itay!
