Moving point to coresponding polygon
  • Feb 4, 2019 3:03 PM UTC
  • 95 views
I have two shape files, one is polygon and second one is point. I need to reposition point shape that are outside of polygon so every point is inside of polygon with same id.
Input:
Output:
Thank you.
  • Feb 4, 2019 3:16 PM UTC
If you mean that the polygon has the same ID as a corresponding point, you can create the inside point of the polygon with the CenterPointReplacer (Mode: Inside Point) and merge all the attributes of the original point to the inside point using the ID as join key (FeatureMerger).
  • Feb 4, 2019 3:19 PM UTC
Agreed. And if you don't have a common ID, you can use the NeighborFinder to find the closest center point from each outside point.
