Move complex geometry to local origo
  • Nov 13, 2018 6:32 PM UTC
  • 5 replies
  • 119 views
sigtill
Forum|alt.badge.img+25
I want to move all different sorts of geometry (points,lines,areas, 3D, surface, faces +++) to a local origo. I can find the correct x,y,z and I can use the 3DAffiner to move most of the data to the correct spot.
However it seems that the complex 3D-geometries that has a Transformation Matrix does not get updated (https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/!FME_Geometry/Transformation_Matrix.htm) .
Is there any easy way to also 3DAffine these Matrixes or do I need to "unwrap" all these geometries and then re-wrap them again. Using deaggregating on all the complex geometires, and then aggregating them again afterwards?
sigtill
  • Nov 14, 2018 8:34 AM UTC
I see this article https://knowledge.safe.com/articles/54027/creating-and-using-geometry-instances.html - is @DaveAtSafe the expert geometryguy at Safe Software - or is there another one even better? I guess this is a difficult question since not even @takashi or @david_r have answered yet :)
  • Nov 14, 2018 8:46 AM UTC
I don't work much with complex 3D geometries at all, so there's my excuse :-)
  • Nov 14, 2018 8:48 AM UTC
Have you tried the Offsetter btw?
sigtill
  • Nov 14, 2018 11:02 AM UTC
Thats the rookie-version of the Affiner :) - But no, didnt try it untill now. Thanks for the tip. I tried it but with same issue.
gio
Forum|alt.badge.img+15
  • Nov 14, 2018 3:10 PM UTC
you could try to
Read the matrix, reverse the transformation(s)?
Then apply your transformation.
and reapply the extracted transformation.
Extract transformation matrix from log as @takashi shows in this thread https://knowledge.safe.com/questions/4813/extracting-transformation-matrix.html
Parse the log (stringsearchers regexp. etc.) to get the trransformmatrix or use , again Takashi's parse python example.
