Most efficient way to count multiple distinct values
  • Oct 13, 2016 10:28 AM UTC
  • 13 replies
  • 688 views
Forum|alt.badge.img+54
I have a workspace producing various outputs, I'd like to produce a further output which details the number of distinct customers and number of distinct products for each output but this appears to be either convoluted involving multiple steps and statistics calculators or slow involving a count distinct in the inlinequerier. Wondering if I'm missing a trick
Best answer by larry
This custom transformer should do the trick.
gio
Forum|alt.badge.img+15
  • Oct 13, 2016 1:17 PM UTC
You can use listbuilder followed by a , listhistogrammer
GroupBy the Attribute you want to have distinct element counted for.
  • Oct 13, 2016 1:36 PM UTC
I don't think that will work, the two things are independent.
e.g. in the following I would want the customer value to be 2 and the product value to be 3
itay
Forum|alt.badge.img+19
  • Oct 13, 2016 2:08 PM UTC
Python to the rescue? or is it R time?
Forum|alt.badge.img+7
Hi @egomm,
When I am in this situation I make use of a PythonCaller in order to create statistics. If you would need some help with that, just let me know!
  • Oct 13, 2016 4:03 PM UTC
itay
  • Oct 13, 2016 5:38 PM UTC
nice, so it was python to the rescue after all....
  • Oct 13, 2016 5:52 PM UTC
Just uploaded it to the hub: AttributeValueCounter
  • Oct 14, 2016 5:00 AM UTC
I also think that Python scripting would be an efficient solution, but if the destination dataset is a database, SQL querying might also be worth to try.
  • Oct 14, 2016 9:02 AM UTC
Perfect,thanks
gio
  • Oct 14, 2016 3:30 PM UTC
@egomm
Your example can easily be solved by..
Matcher followed by a statisticscalculator grouped by fme_feature_type...
Put in a custom for ease of use...
When using custom explode the features so you can use attr_name as input
No need for python or whatever.
And if its in a database then of course you would use sql.
I am trying to use this transformer to count all the unique values in a column. but does seem to work. need some help. My data as below.
A
1
1
1
2
3
0
0
Output should look like:
0 -> 2
1 -> 3
2 -> 1
3 -> 1
  • May 2, 2018 2:22 AM UTC
A
1
1
1
2
3
0
0
0 -> 2
1 -> 3
2 -> 1
3 -> 1
Hi @sobanmughal, The AttributeValueCounter counts the number of distinct values for each attribute, I don't think it's suitable to your requirement. You can just use the StatisticsCalculator here. Set these parameters and check the resulting features output from the Summary port.
  • Group By: A
  • Attributes to Analyze: A
  • Total Count Attribute: <an attribute name which will store desired count value>
  • Group By: A
Thanks takashi, I have found another custom transformer that can do the same thing.
UniqueValueLogger
https://hub.safe.com/transformers/uniquevaluelogger
