More complex SQL querying in a ArcSDE Reader WHERE-Clause?
  • Feb 21, 2023 8:05 AM UTC
  • 238 views
takanaka
Forum|alt.badge.img+5
I'm looking for some help to use SQL in 'where clauses' for FME Readers.
I'm trying to read from an ArcSDE database, using SQL operations like GROUP BY or DISTINCT. But I am under the impression that ArcSDE is not compatible with more complex statements than the simple terms like: equals/is null/not null/ in range / and so on.
On the documentation page I read however: "Enter any SQL where clause that constrains the attributes of the layers selected in the layer list."
I have found the SQLCreator and SQLExecutor transformers, however these do not support ArcSDE format.
I'm starting to think that the ArcSDE format simply does not suppport 'advanced' SQL querying in FME. Is this correct?
So far I have found 1 alternative: a PythonCaller using these ArcSDESQLExecute functions from ArcPy.
Could someone tell me if this is indeed the only workaround? Are there other workarounds? I've not found any further documentation on this topic, perhaps someone else has some useful references for me?
Best answer by markatsafe
@takanaka​ Geodatabase has been added to the list of formats supported by SQLCreator/Executor for FME 2023 - due for release in early April. You can test the functionality in the FME 2023 betas if you wish. There are very likely nuances on what SQL is supported based on the underlying database etc. FME doesn't use ArcSDESqlExecute functions. I think you could probably use this as a guide to what SQL is supported.
  • Feb 21, 2023 7:19 PM UTC
ctredinnick
Forum|alt.badge.img+22
  • Feb 21, 2023 9:11 PM UTC
You can use a FeatureReader and construct a where clause using things like GROUP BY and DISTINCT, since a FeatureReader in this situation is just doing a select * from table.
Something like this:
OBJECTID = (SELECT MAX(OBJECTID) FROM MASTER.TABLE)
OBJECTID in (SELECT MAX(OBJECTID) FROM MASTER.TABLE GROUP BY Other_Field)
is a way to use aggregate functions like GROUP BY
You can even add in SQL spatial to test for overlaps with input areas
SecondaryID in
(SELECT SecondaryID
FROM MASTER.TABLE_evw
WHERE PropertyID = @Value(PropertyID)
AND SHAPE.STIntersection(0x@Value(_geometry)).STArea() > 0.9
