Mongodb and date format
  • Jan 25, 2020 1:20 PM UTC
  • 6 replies
  • 154 views
pg.souque
When i insert with the jsontemplater a date in the mongodb writer the type of date is always string even i choose isodate, fmedate......etc. Can i have a type date in mongodb via the jsontemplater ?
Thanks a lot
pg.souque
  • Jan 25, 2020 1:56 PM UTC
Precision: insert with Document source= Json attribute
  • Jan 25, 2020 3:40 PM UTC
Hi @pg.souque, according to the MognoDB Extended JSON specifications, an object with this format represents a value with date type.
{"$date": "<ISO-8601 Date/Time Format>"}
It seems that the ISO Date/Time has to be UTC date/time ending with the timezone suffix 'Z'. For instance, try inserting this JSON text into a MongoDB collection.
    "event_name" : "FME World Tour 2020",
    "kick_off" : {"$date" : "2020-03-10T10:00:00Z"}
pg.souque
  • Mar 2, 2020 11:01 AM UTC
It works. Thank you very much !
pg.souque
  • Nov 24, 2023 7:51 AM UTC
Hello,
I have now this problem
How to convert a format $date from mongodb ?
The reader had for example this format: "date":{"$date":1337904000000}
In studio 3t format is for example 2012-05-25T00:00:00.000Z
I can't tranform "$date":1337904000000 with DateTimeConverter...
Help !!
geomancer
Forum|alt.badge.img+71
  • Nov 24, 2023 8:16 AM UTC
According to the Mongodb documentation, they use something called theBSON Date data type, which is a 64-bit integer representing the number of milliseconds since the Unix epoch, which was 00:00:00 UTC on 1 January 1970.
With this information, you can calculate the correct date.
pg.souque
  • Nov 24, 2023 11:04 AM UTC
Thank you for your response
I tried with delete the 3 last characters (000) and format %s$....it works, thank you very much
