Modify existing table schema
  • September 7, 2021
  • 207 views
helmoetz
Forum|alt.badge.img+15
Is it possible to have FME modify the schema of an existing table? Say I have a table with name mytable and attributes attr1, attr2 and attr3, coming from the import of an external dataset. A new version of the dataset contains a new attribute, or the data type of an attribute changes from char to int or so. We do not want to drop and recreate the table, since quite a load of triggers, user rights and stuff is dependent on the table. Basically we want to truncate the table to the new schema. Is that doable in FME, has anyone experimented with that?  I guess I could use something like
SELECT
FROM
  information_schema.columns
WHERE
  table_name = 'mytable'
(we use Postgis), check the results and compare them to the new version of the dataset, and if differences, generate and execute the necessairy ddl statements by FME, but I'm not sure if we should go that way.
  • September 7, 2021
For what it's worth, what you're describing is pretty much what I'd do.
  • September 7, 2021
@Helmoet de Zwijger​ FME can't modify the table schema, so you have to construct the DDL statements and run those using SQlexecutor, as you suggest.
But... in FME 2022 we have added a new transformer - SchemaScanner that might make the comparison of the new and old schemas a little easier. Available in FME 2022 betas if you want to kick the tires. Should replace the FME HUB SchemaSetter
helmoetz
  • September 9, 2021
Thanks for the answers!
