Missing z-value when writing GIS data to DWG
I am reading some data from a ESRI based web GIS and need to convert them to DWG. The data contains XYZ data, but the Z-values are missing when opening the DWG in CAD-software.
I got Z-values before writing:
This is my workspace:
AutoCAD:
How can I make sure the file contains Z values?
dustin
Forum|alt.badge.img+31
  • October 4, 2022
Are your Z values being passed through each of your transformers. In other words, if you inspect the features coming out of the Reprojector, are your Z values still present?
  • October 5, 2022
I solved the problem by moving the DWGStyler before SurfaceDraper. It looks like the DWGStyler forced the feature to be 2D some how.
