MISSING_REFERENCEE_KEY error applying imagery to geometry
  • December 18, 2018
  • 87 views
Hi All,
I'm trying to apply geotiff imagery to 3d roof geometry with the Top Down Georeferenced method (using Attribute Join within the transformer). The geometry is rejected and encoded with the MISSING_REFERENCEE_KEY string.
Any help is much appreciated!
Thanks,
Charles
  • December 18, 2018
Appearance cannot be set onto Polygons. Try inserting the FaceReplacer before the Aggregator to replace each Polygon with a Face.
