Mismatch between nb parts (counter) and outputs deagregator
  • Mar 3, 2020 2:27 PM UTC
  • 40 views
tsirkuse
Forum|alt.badge.img+4
Hello,
I am slightly confused and probably missing something with Deaggregator (or part counter).
When I run part counter, I find out that 3 of my 48 features are multi-part.
However when I want to deagregate those parts, one of these 3 features has no part number and isn't deaggregated.
This file contains the 3 multi-part features, but only 2 of these are split up.
The problematic multi-polygon has a donut hole, but this is the same for one of the other polygons and there it doesn't cause problems.
Any ideas ?
Forum|alt.badge.img+54
  • Mar 3, 2020 3:34 PM UTC
If you have a line that is a path, the PartCounter will count the number of lines that make up the path, but the Deaggregator will not split. You would need to use a path splitter to split these features
