Minimum volume of a point cloud as a mesh
  • Apr 24, 2023 8:43 AM UTC
  • 0 replies
  • 95 views
Hi there!
I have a point cloud representing a dense forest. I am trying to get the 3D convex hull of the point cloud (as a mesh). I have already tried PointCloudToPointCoercer (individual points) into HullAccumulator but the results are unexpected and do not contain the whole point cloud:
Point cloud and HullAccumulator result
Using the Minimum Bounding Volume tool in ArcGIS Pro does the trick, but since the rest of my workflow is in FME, I would like to avoid this option. Is there an FME alternative to this tool?
Here is the result produced by Minimum Bounding Volume in ArcGIS Pro:
ArcGIS Pro result and point cloud
Hope someone with knowledge of 3D models in FME can help. Thank you!
