I'm looking for the FME transformator equivalent to QGIS Minimum Bounding Geometry in order to extract the orientation (azimuth) of the feature shape. This topic is not relevant as it refers only to hull because the concern is about the angle of bounding rectangle, i.e. main direction of the geometry (polygon).
Minimum bounding geometry - oriented rectangle
Best answer by DanAtSafe
Hi @albinepro In FME 2022.1, it's now possible to set an attribute for "Long Side Angle" in the BoundingBoxReplacer if the feature is replaced with a "2D Oriented Bounding Box".
cc @jdh
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
